motoxjosh29
Feb 13, 2020Tutor
wireless device disconnecting several times throughout the day R6700v3
hello, i do not see a later date of this discussion so i figured i would ask. i have a R6700V3 AC1750 nighthawk router running V1.0.4.84 with auto update on. i have anywhere from 7-10 wireless ...
- Feb 13, 2020
motoxjosh29 wrote:thanks for the discussion. i will try this tonight.
it is a combo device... i'm pretty green at most of this, but i think the only way to avoid the double nat issue, is to setup bridge mode if its supported in both devices. OR ask for a dedicated modem only.
Most devices have a modem only mode. Disabling wireless doesn't do it. Or if they don't have a modem only/passthrough mode, you leave that specific device running in router mode and would put the R6700 in AP (access point) mode. this prevents the double nat.
Feb 13, 2020Guru - Experienced User
motoxjosh29 wrote:it was on 5ghz and i switched it to 2.4ghz a few days ago. still the same problem with that device.
its a kindle fire 7, 2017 version i believe.
my modem is the netgear frontier standard dsl with the wifi diabled. sorry, i can get specific version when i get home.
im wondering if i can do a forget network, on the tablet, and try to refresh the connection. what i think is happening is when the device list name changes, it gets disabled then...
worth a shot.
its also worth looking at the modem. if its a combo device (router and modem) and you're running the R6700 you could have a double nat issue. Usually you see problems on more than 1 device but stranger things have happened.
motoxjosh29
Feb 13, 2020Tutor
- plemansFeb 13, 2020Guru - Experienced User
- motoxjosh29Feb 18, 2020Tutor
so i finally figured out how to get that modem/router combo into bridge mode. it has been working all weekend without kicking any devices off the network. thanks for the help i would of never gotten that kind of answer from frontier if i called in.
i attached a pretty good pdf version of a website i found to help get that combo frontier unit into bridge mode. once again plemans thanks for the help!
- plemansFeb 18, 2020Guru - Experienced User
Glad to hear you go it working well! and we appreciate the pdf for others who have this issue.
thanks!
