motoxjosh29
Feb 13, 2020Tutor
wireless device disconnecting several times throughout the day R6700v3
hello, i do not see a later date of this discussion so i figured i would ask. i have a R6700V3 AC1750 nighthawk router running V1.0.4.84 with auto update on. i have anywhere from 7-10 wireless ...
- Feb 13, 2020
motoxjosh29 wrote:thanks for the discussion. i will try this tonight.
it is a combo device... i'm pretty green at most of this, but i think the only way to avoid the double nat issue, is to setup bridge mode if its supported in both devices. OR ask for a dedicated modem only.
Most devices have a modem only mode. Disabling wireless doesn't do it. Or if they don't have a modem only/passthrough mode, you leave that specific device running in router mode and would put the R6700 in AP (access point) mode. this prevents the double nat.
motoxjosh29
Feb 13, 2020Tutor
Feb 13, 2020Guru - Experienced User
