larryhaskell
Feb 28, 2016Aspirant
Wireless Devices shows MAC Address for 1 device that doesn't have an IP Address
I'm tracking down every device attached to my nighthawk router and I've identified every one except this. There is a Wirelsss Device listed when I log into the router that does NOT have an IP address...
- Mar 03, 2016
Try to turn off the extender and see if that will still populate.
larryhaskell
Mar 03, 2016Aspirant
My router is AC1900 Smart WiFi Router Model: R7000. The Wireless Range Extender is AC1900 EX7000 although, unlike my other devices, has no label on the device itself. The address in quesiton is C0FFD48F847F. I used the web to lookup the manufacturer based on the first 6 digits of this number. The vendor is netgear. The lookup site is http://aruljohn.com/mac.pl
ElaineM
Mar 03, 2016NETGEAR Employee Retired
- larryhaskellMar 03, 2016Aspirant
It worked. The mac address disappeared when I powered the wireless router off. I've still got to rationalize why but it did answer what it was. Thanks for your help.
- ElaineMMar 04, 2016NETGEAR Employee Retired
You're welcome. It is most probably because that's the virtual mac address.
