MartinaD
Nov 10, 2020Aspirant
Wireless Internet Access from both an R8000 and a R6700
My current setup is the R8000 is hard wired to a cable modem (Spectrum model E31N2V1), with the 2.4GHz and both 5GHz broadcasting. The R6700 is in a separate room with a printer. The R6700 has both...
Nov 10, 2020Guru - Experienced User
What version of the R6700 do you have? There was 3 versions. Versions 1 and 2 both supported extender/repeating mode.
That's the mode you're looking for.
https://kb.netgear.com/24108/How-do-I-enable-the-extender-mode-feature-on-my-Nighthawk-router
Bridge mode literally turns a router into a wireless bridge where it doesn't rebroadcast. it basically connects it back to the primary router over wireless and lets it function as a switch.
The R8000 doesn't have extender/repeating mode.
- MartinaDNov 10, 2020Aspirant
The model I have is the R6700v2.
So, if I understand you, this means I should connect the R6700 to the cable modem, set it up in repeater mode, and use the R8000 as the remote. Correct?
- plemansNov 10, 2020Guru - Experienced User
No. The R6700v2 would be the repeater.
the R8000 would be primary router.
