vish20006
Feb 22, 2021Follower
Wireless PCI Adaptor WG311v3 driver installation in windows 8.1
Hi Team, I have windows 8.1 verion 6.3 9600... Issue: PCI hardware detected but driver not installed successfull.. it happen once done ok.. but due to system corrupt.. I hve done all things r...
michaelkenward
Feb 23, 2021Guru - Experienced User
Netgear's drivers don't work?
Not sure where in this community you should pose a question about an ancient (2003) device that Netgear no longer makes, but whatever the issue, you probably won't get much help in a section given over to Nighthawk WiFi Routers.
