Patreek
Feb 09, 2019Tutor
Wireless Repeater Nighthawk R6700v2
According to many sources on the forums, my R6700v2 is capable of acting as a wireless repeater. I have seen a literal ton of advanced features for the router and am impressed, but I see nothing abo...
- Feb 10, 2019
I'm going to return both units and avoid Netgear all together. I honestly can't comprehend why they would include so many features I do not need on a wireless router, but not wireless repeating.
michaelkenward
Feb 10, 2019Guru - Experienced User
Some Netgear routers support WDS, some don't, including the R6700v2. It is, after all, somewhere low on the performance and features scale.
I chip in only to suggest that there is a slight possibility that, while they seem to concentrate on more "upmarket" models, one of the third-party firmware writers has tweaked this device and added extra features. But this isn't the best place for that sort of discussion.
You can use the R6700v2 as a WiFi Access Point with a wired connection to a router.
Patreek
Feb 10, 2019Tutor
