gunrhuntr's avatar
gunrhuntr
Follower
Dec 27, 2020
wireless router
How do I get this nighthawk router to pick up a signal from my house using a antenna that I connected to the back of it? Wanting it to pick up my wifi signal?
  • plemans's avatar
    I'm not sure what you're attempting to do.
    do you already have a router and you're wanting it repeated?
    Are you signed up for an ISP that supplies internet through a wireless broadcast like a point to point system?
    What actual devices/setup do you have?
    You didn't give us much to go off for what you're doing or what your current setup is so its tough to go over anything.
  • michaelkenward's avatar
    michaelkenward
    Routers don't "pick up" a wifi signal. They broadcast it.
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
