NetRags
Jul 14, 2016Tutor
Wireless security options with explanations
Hello Team, I would like to have your knowledge base updated with the types of security options available in IEEE and supported security options on NETGEAR router with detailed description. The c...
ElaineM
Jul 15, 2016NETGEAR Employee Retired
Hello NetRags
Welcome to the community!
Thank you for your input. Can you tell me more on what would you want to see on these articles?
- NetRagsJul 22, 2016Tutor
Hi Elaine,
Would be better if we have the article updated with the below sample info
Wireless security types available in NETGEAR Gateways/Routers
1. WEP
2. WPA-PSK (TKIP)
3. WPA-PSK (TKIP) + WPA2-PSK (AES)
4. WPA2-PSK (AES)
5. etc..
Example:
What is WEP security?
> Definition
> Description about Key index (Key1,2,3,4)
> What is the purpose of Generate button when WEP security is selected
> etc
Prons
> Supported by almost all the wireless devices including Win-XP, Amazon Kindle etc...
> etc
Cons
> Low security strength
> Networking geeks can easily crack the password
What is WPA-PSK (TKIP)
WPA:
PSK:
TKIP
Prons
ConsThis information not just helpful your valuable customer also helps your phone support representative to get familiarize on these. So that they can avoid blabbering when customer asked about the differences b/w security types.
Thanks & Regards,
NetRags
