Bakera
Jun 11, 2017Aspirant
Wireless Setting Issues
Earlier today my phone suddenly disconnected and was unable to reconnect to the router. My computer and playstation 4 are connected via lan cables, but my smartphone (1+3t) has been unable to connect...
- Jun 12, 2017
The wifi LED is also a button that is a switch.
See page 12 of the manual
R7000 | Product | Support | NETGEAR
michaelkenward
Jun 12, 2017Guru - Experienced User
You don't have a young son, or a pet animal, that turned off the wifi with the switch on top of the router do you?
A case of that came up here over the weekend.
- BakeraJun 12, 2017Aspirant
That's a possibility. But I don't see any switches on the top of my router large enough for a cat to flip or press into.
Where exactly would I find it?- michaelkenwardJun 12, 2017Guru - Experienced User
Well isn't my face red.
Thanks for the quick response!!
