ChrisUlrich
Nov 22, 2016Tutor
Wireless speed issue
I am trying to figure out what settings I am supposed to be using in order to utilze the downstream speeds full potential. I have plenty of wireless ac devices, but none seem to be getting the full ...
- Nov 23, 2016
Did exactly what you said to do! Two other signals were on my channel (originally 153 but Netgear recommended 157). Found a channel not being used, swapped it (channel 40), did speedtest on the iMac... pow! 232mbps down!
Thank you so much for the advice and assistance. Excellent directions and help. You really made my night!
michaelkenward
Nov 23, 2016Guru - Experienced User
Wireless will never be as fast as wired.
A lot depends on local conditions and how many devices are fighting for the bandwidth.
Do you find that you can't do things you want? Or is this just a desire to get faster speed tests?
Don't forget, Internet speed tests are not as reliable when you use wifi to run them. Some speedtest sites warn about this.
ChrisUlrich
Nov 23, 2016Tutor
The idea is to make sure I am getting the speeds i'm supposed to via wireless.
Wired is more than double my wireless connection? I don't think that's supposed to be that way.
- TheEtherNov 23, 2016Guru
What kind of device do you have? If it's a PC or laptop, provide the model of the Wi-Fi adapter.
- ChrisUlrichNov 23, 2016Tutor
2016 MacBook Pro with Touchbar
2015 27" iMac
Gen IV Apple TV
Amazon Firestick
Sony XBR-55X930D
All 802.11AC Certified.
None are getting even close to 200mbps. Right now, latest test... they're getting 5mbps. 5!
Option-Click the Wi-Fi icon, and provide the following:
Channel
RSSI
Noise
Tx Rate
PHY Mode
MCS Index
Run a Wi-Fi analyzer and take a survey of Wi-Fi networks. Make sure none of the nearest ones are using the same channel. If they are, then change your Wi-Fi channel.
You can use open System Information and go to the Wi-Fi section to get a listing of nearby Wi-Fi networks.
