Csafran
Mar 11, 2024Aspirant
Wireless speeds with Comcast and nighthawk
Frequently, every few weeks I noticed that my wireless Internet speed is very very slow. If I am plugged my nighthawk for a few seconds and re-plug it in my wireless Internet speed become normal again...
Csafran
R8000
Mar 13, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What channel configurations are currently set on the router?
What devices are you speed testing with?
Is Smart Connect enabled or disabled?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
