mikecharest
May 02, 2017Aspirant
wireless stops working on Nighthawk R7300 when AC1900 WiFi Range Extender is connected
My wireless keeps stopping and requires either a reboot of the router to work or reapplying the settings to fix. Both routher and repeater have the latest firmware Firmware Version V1.0.0.46_1.0.13 ...
- May 09, 2017
Hi mikecharest,
I would suggest to contact Geeksquad to better isolate the issue. You can try to reset the router and the repeater and manually reconfigure.
JamesGL
May 09, 2017NETGEAR Employee Retired
Hi mikecharest,
