JS3269
Jan 17, 2020Aspirant
Wirelessly connecting C7800 to R7800
My C7800 is located on my main floor with the coax line, I am not receiving the speeds or signal I desire in my office which is on the lower level and on the other side of the home. I would like to ...
- Jan 17, 2020
1. Set the R7800 up in AP mode and connect Ethernet to the C7800 and run it as far as you can in the direction of your office. Even if you can't get it all the way there, can you get it 'most' of the way there? The closer you get, the better the speeds will be.
2. Do you have PC's with Ethernet in the office? If so, set up the R7800 as a wireless bridge (look in manual for how) in your office. The R7800 connects wirelessly to the C7800 and then provides internet via the ethernet jacks (NOT WAN jack) on the R7800 (so PCs connect ethernet to R7800, which connects wirelessly to C7800). If wireless devices in the office are 2x2 devices, this has the 'potential' to double speeds (as R7800 is 4x4).
duckware
Jan 17, 2020Prodigy
michaelkenward
Jan 18, 2020Guru - Experienced User
If you don't want to run Ethernet cables around the place, then you can use Powerline Ethernet instead.
Just plug the R7800 up in AP mode into the "guest" plug.
- duckwareJan 18, 2020Prodigy
What throughput (Mbps) results do you get from powerline? I am seeing reviews (and live tests in YourTube reviews) showing 20 Mbps to 300 Mbps results.
- JS3269Jan 18, 2020AspirantI was getting 290mbps through bridge and direct Wi-Fi to the C7800
When I connected Netgear powerline1000 I got 47, 32, 56 Mbps
Newer home 1999 so should not be an issue with wiring unless they are on different circuits or some sort of terminal issue at an outlet- duckwareJan 18, 2020Prodigy
By any chance does router room and the office both have coax TV cables? I am thinking about MoCA ethernet adapters (where reviews and speeds tests seem very good).
- JS3269Jan 18, 2020AspirantActually tried the power line verified the connection was correct and it cut my speed 75% of what I had. Already returned to Amazon.
