Kknits
Dec 15, 2021Aspirant
wirelss devices can't connect R6700v2
My modem and router are working. Wired devices can connect to the internet. Wireless devices cannot conncet. Any ideas?
Dec 15, 2021Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
wcalifas
Dec 15, 2021Prodigy
someone maybe accidently pressed the wifi button on the router maybe? There's a wifi on/off button which is one of the LED's on the right part of the router. Press the LED for the wifi for 3-5 seconds and see if it turns back on.
