StanH
Jun 24, 2021Tutor
With Nighthawk R7000 connected USB to printer, how can I print from Android phone over WIFI?
My Nighthawk R7000 is connected USB to the printer. How can I print from my Android phone over WIFI? Printer: Brother MFC8860DN Phone: Google Pixel 2 XL Android: vesion 11
Kitsap
Jun 24, 2021Master
Have you tried installing the Brother iPrint&Scan application from the Google Play Store on your phone?
StanH
Jun 24, 2021Tutor
Brother iPrint&Scan can't locate the printer.
- KitsapJun 24, 2021Master
StanH wrote:Brother iPrint&Scan can't locate the printer.
Have you downloaded the manual and read chapter 11 on sharing a USB printer?
Sharing a USB printer requires use of the Netgear ReadySHARE utility for computers. Not the smoothest approach to sharing a printer on the network.
You may not have a path to print from a phone without a network capable printer.
- StanHJun 24, 2021Tutor
I use readyshare vault.
I can print smoothly through the R7000 from a Windows 10 wireless and Windows 10 Ethernet. But the Android doesn't see the printer even though it is on the same wireless workgroup as the router and the Windows computers.
- KitsapJun 25, 2021Master
The computers print via the ReadySHARE utility. There is a ReadyCLOUD utility for phones but it apparently does not support printing.
There may not be a path to print from a phone unless your printer is connected to the network via an ethernet cable. i.e. you can't get there from here.
