StanH
Jun 24, 2021Tutor
With Nighthawk R7000 connected USB to printer, how can I print from Android phone over WIFI?
My Nighthawk R7000 is connected USB to the printer. How can I print from my Android phone over WIFI? Printer: Brother MFC8860DN Phone: Google Pixel 2 XL Android: vesion 11
antinode
Jun 24, 2021Guru
> My Nighthawk R7000 is connected USB to the printer. [...]
Doesn't the "N" in that model number stand for "Network"? If the
printer has its own network capability, then why would you use a USB
connection to a router with Netgear-quality print-server software?
> [...] How can I print from my Android phone over WIFI?
How do you use _any_ networked printer from an Android device?
StanH
Jun 24, 2021Tutor
My MFC8860DN is not network capable.
