wolframmitbach
Dec 07, 2015Aspirant
WLAN schedule cannot be activated
I find this topic again and again in the forum but no solution for me. I want to activate 'Turn off wireless signal by schedule' but the box cannot be checked. I'm using the R7000 as a Router it's ...
- Dec 09, 2015
Thanks it works now!
I didn't use WLAN scheduling bevor
JamesGL
Dec 08, 2015NETGEAR Employee Retired
Hi wolframmibach,
Please reset the router to factory default and check if the you can enable it. By the way, was it working before prior to upgrading the firmware?
wolframmitbach
Dec 09, 2015Aspirant
- JamesGLDec 12, 2015NETGEAR Employee Retired
Glad to know it works now.
