Pop9
May 27, 2022Guide
WLAN0 Tuya Connected Randomly to My Networks
As stated, this device read only connected to my network. I searched the MAC address of 18:69:D8:4F:78:2B and it says manufactured by Tuya. I have no clue what this device is though. Any insight would...
May 27, 2022Guru - Experienced User
Do a web search on the mac addresss and that brand name.
What NG product are you using?
- Pop9May 27, 2022GuideSorry, do what exactly?
- Pop9May 27, 2022GuideAre you meaning my RBR750?- FURRYe38May 27, 2022Guru - Experienced UserOH there it is. Thank you. What happens if you change the wifi SSID name and PW to something else temporarily. Does that MAC address and device still appear? Change back after checking this. Do a web search on the brand name you find.
