BXERRI
Feb 04, 2021Aspirant
WN3000RP Extender not working with NBN
Hi, I have one of these extenders that I used to use with my home ADSL set up. I want to use it with NBN now that I have that but not sure if it can be. Any advice would be appreciated. Bri...
antinode
Feb 04, 2021Guru
> WN3000RP [...]
WN3000RP[v1], WN3000RPv2, or WN3000RPv3? Look for "Model" on the
product label.
> [...] I used to use with my home ADSL set up. [...]
Not a very detailed description of that equipment.
> [...] I want to use it with NBN now that I have that [...]
About all that that says is that you're in Australia.
> [...] but not sure if it can be.
I'd expect so, within the limits of its capabilities. The WN3000RP
is an old, relatively slow ("n"), 2.4GHz-only gizmo. Something newer
might be faster. Whether you'd care, I couldn't say.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get some. Compare its specs with those of your
(unspecified) new router and/or some newer extender.
Do you know that you'll still need an extender with your
(unspecified) new router?
BXERRI
Hi Antinode,
I appreciate the response and sorry for poor information. Here is a little more information. It is a WN3000RP V1H2 model, old I know. I just did not want to buy a new one if I did not need to. The WiFi router (NBN) that I am connecting to is a NetComm CloudMesh Gateway Model NF18MESH.
The set up is in a house and you are right, I don't really need the extender in it but it has a separate cottage were the WiFi range is marginal and I thought, if I could use this, it would be great. I have tried of course and I can see the Extender come up on my phone when it is plugged it but cannot connect to it. I have tried a Factory Reset with the pin button on the side.
Kind regards,
Brian
antinode wrote:> WN3000RP [...]
product label.
