BXERRI
Feb 04, 2021Aspirant
WN3000RP Extender not working with NBN
Hi, I have one of these extenders that I used to use with my home ADSL set up. I want to use it with NBN now that I have that but not sure if it can be. Any advice would be appreciated. Bri...
michaelkenward
Feb 05, 2021Guru - Experienced User
There is nothing special about the WN3000RP. It should work with whatever type of Internet you throw at it, even NBN, which is not so much a technology as a label that means "Australian Internet". We don't even need to know which of the various flavours of NBN you have.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Look for the model number on the label on the device. Pay attention to any V number. If it doesn't say V2 or V3 it is V1.
Begin with the Installation Guide. First reset the WN3000RPto remove any old settings carried over from the ADSL service.
You may have done this already. I can't tell from your message.
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
