ValeDS
Dec 22, 2020Follower
WN3000RP LAN extender - PC to Extender doesn't work
I had reconfigured my Net extender because I changed my TLC operator.
Now the Link Rate LED is GREEN, but the PC to Extender LED is now always RED.
From different devices I can see The Extended Network, but can't obtain an internet connection..
There may be a compatibility problem between the extender and the new router? Otherwise, how can I solve the problem?
Please, help me..
1 Reply
What's that? A different Internet service provider?
ValeDS wrote:
....the new router?
What's that?
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Begin with the Quick Start/Installation Guide.
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)As the name suggests, the WN3000RP is not a Nighthawk WiFi Router.
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
