camykoby
Jan 05, 2022Follower
WN3000RPv3 Important Security Update needed
I am receiving emails saying that I should update my firmware. There are various options given in the email to do this. When I log on to the website, I don't see any of the options they mention. Very...
Jan 05, 2022Guru - Experienced User
You may need to manually update the extenders FW by manually downloading the FW file and applying it manally using a wired PC and web browser.
https://www.netgear.com/support/product/WN3000RPv3.aspx#download
https://kb.netgear.com/000064383/WN3000RPv3-Firmware-Version-1-0-2-100
Netgear has set up a community forum specifically for the WiFi Extender products. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
Thank you.
