slatnet
Jan 15, 2021Initiate
WNDR4300V2 Speed capability
Our internet service provider just installed a new modem, and said that our router may struggle with the 200mbps download speed. Our router WNDR4300V2 is a bit older, but is still a gigabit routher,...
Jan 15, 2021Guru - Experienced User
You're not out anything to try it and see how well it works for you.
If it doesn't, then upgrade. If it meets all your requirements, then you're good.
