jpr35
Mar 02, 2021Aspirant
WNR2000-5 in AP mode doesn't prevent guest user to access my personal home network
Hello there I have been using a WNR2000v5 in AP mode for a few years, and recently i discovered that my guest can acces my home network by using the WiFi guest network . I beleived that using the W...
- Mar 07, 2021
OK thanks
jpr35
Mar 03, 2021Aspirant
Hello Antinode
Thanks for your reactivity and your explanations
1) As far as i undertsand your answer, the network isolation between WiFi guest network and my domestic network is not possible , because this feature doesn't exist in AP mode .
2) I had not understood this point before buying this router, despites the questions i asked to the Netgear advisor in France, anyway ...
3) Let me explain what i try to make :
-I am renting an appartment in my property which is too far from my home to receive the WiFi signal from my ISP modem router, and in order to overcome this problem, i have installed in the guest appartment the WNR2000v5 (the device is hidden behind a piece of furniture) which is linked to my router with a CAT6 Ethernet cable.The aim is to offer Internet acces only to the guest and prevent him to acces my home network.
4) is there a way to acheive point 3 objective ? for example by using the WNR2000v5 in router mode behind my ISP router , knowing i cannot use the WNR2000v5 in the place of the ISP router .
Thanks a lot in advance
Kind regards
antinode
Mar 03, 2021Guru
> [...] for example by using the WNR2000v5 in router mode behind my ISP
> router [...]
You can try that. Cascading multiple routers can cause problems for
servers and some games (double NAT, for example), but for simple web
browsing and the like, it might do well enough.
- jpr35Mar 07, 2021Aspirant
OK thanks
