thlobato
Jul 30, 2021Aspirant
WNR2000 v2 - all solid lights on
hello there. Im been using the netgear wnr2000v2 for a while with dd-wrt fw. its been working fine since I stop using it as a repeater and tried to use it as a wifi-repeteater. there are a lot of t...
thlobato
thanks for fast replying.
im reccuring to this community once I reached all software methods to debrick this router.
So if you may help somehow it will be welcome.
Jul 30, 2021Guru - Experienced User
If its got 3rd party firmware, our help could make it worse as some 3rd party firmwares require certain steps/procedures for recovery
- thlobatoJul 30, 2021Aspirant
So, are you saying that this symptom (all lights of the router solid) its specific of a firmware??
This wouldnt happen in a regular netgear fw?- antinodeJul 30, 2021Guru
Who knows? Your router has a problem which could be in the firmware
or the hardware. Most of the people here know little about DD-WRT, and
nothing about your hardware.> [...] I cant reset, hard reset [...]
What's the difference? What, exactly, do those terms mean to you?
"can[']t" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.> [...] and cant also unbrick it by tftp bc it cant boot up and give me
> an IP address at al.
Wrong. Have you looked at the TFTP recovery procedure? It
specifically requires the user to assign static IP parameters to the
computer because DHCP is unavailable. See, for example:- thlobatoAug 01, 2021Aspirant
Let me say it better
- the router doesnt gimme an IP.
I mean: I cant ping the router by static ip that has been set.
thanks guys.
But Its an older router, I just put it on the trash.
