KorporalKrump
Feb 02, 2021Initiate
WNR2020v3 can't get IP address from R6700v3
I have been trying to set up my home network with a 2nd router that I want to use as a guest network WiFi on a separate vlan. I had this mostly working in the following configuration: Ubee Cable...
- Feb 02, 2021
Just in case anyone comes across this in the future, the issue was the unmanaged switch. I hooked up the WNR2020 directly to one of the ethernet ports on the R6700 and was able to resolve my issue.
KorporalKrump
