winger13
Dec 19, 2018Guide
WOL recently stopped working for Static IP PC attached to R7000, Telnet to R7000 update ARP ?
WOL from a laptop was working on my network for the one PC (hardwired to a switch, which is hardwired to the R7000) with a static IP address for the past three + years. Recently, WOL stopped working....
- Dec 21, 2018
this thread may be of some use to you https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Wake-On-Lan-with-R7000/td-p/379989
DarrenM
DarrenM
Dec 21, 2018Sr. NETGEAR Moderator
DarrenM
- winger13Dec 31, 2018GuideThis post does not help. I already downloaded the telnet took. I am asking how I can verify I am logged into the R7000 using the telnet tool. After I issued the username/password command, I do not see any prompts
