StanleyY
Oct 19, 2021Follower
Would Nighthawk M5 5G WiFi 6 Mobile Router Unlocked works in Hong Kong?
Hello community, I would like to know if Nighthawk M5 5G WiFi 6 Mobile Router unlocked works in Hong Kong Region? I checked Hong Kong 5G frequency band are n1, n78 and n79, so I assume that is w...
michaelkenward
Oct 20, 2021Guru - Experienced User
A question for the section dedicated to those devices.
Mobile Routers, Hotspots & Modems
Those things are very different from the standard Netgear routers covered in this section.
