Kitokedoki
Jun 07, 2021Tutor
WPA disabled in Security Options
Hello everyone! I have a router WGR614v9, it is ~10 years old. I want to change the security level from WEP to WPA, but they are disabled. I updated the firmware to the latest version, it did not hel...
Jun 07, 2021Guru - Experienced User
Did you ever try simply factory resetting the router and reinstalling it using wpa/wpa2?
Kitokedoki
Jun 21, 2021Tutor
Hello! Thanks for your advice, factory reset helped, my "relic" works now with WPA :)
