pappoux
Sep 13, 2021Follower
WPA password and Security key for use with HP Printer Where do I get them. Did not come with my Cabl
Sep 13, 2021Guru - Experienced User
What modem/router/device do you have?
did you setup/change your ssid/password?
If you go to netgear.com/support/ type in your actual model number. It takes you to guides, firmware, etc for help
