GKBARCH
Oct 22, 2021Follower
WPN824N - MY PHONE CONNECT TO IT FOR WIFI BUT THE UTUBE DOES NOT FEED CONTINUOUS. IT KEEPS PAUSING
MY WPN824N - IS MY WIFI VIA MY CELL PHONE BUT THE YOUTUBE DOES NOT FEED CONTINUOUS. IT KEEPS PAUSING. I AM WONDERING IF THIS A ROUTER PROBLEM OR WHAT. I HAVE TWO CELLS THAT CONNECT TO THIS ROUTER AND THEY BOTH BVEHAVE THE SAME. WHEN I CLICK ON A VIDEO, IT TAKES FOREVER TO COME UP AND THEN IT INTERUPTS AND SEEMS TO CONTINUE TO RELOAD. THE RESULT IS CONSTANT START-STOP-START-STOP.
JUST LET ME KNOW IF I AM RIGHT OR NOT.
I WILL CHECK MY EMAIL TOMORROW. GKB@ARCHITECTGKB.COM
THANKS
GKBARCH
1 Reply
That is a really old router from 2009 that was a base model at that time 12 years ago.
A really basic N150 router with 10/100mbps ports.
What speeds do you pay for from your ISP?
Unless its pretty low dsl speeds, I'd highly recommend upgrading to a newer router versus troubleshooting it.
If you do pay for low speeds, that'd be the explaination for why its buffering.
