glennf0908
Dec 02, 2021Aspirant
WPS process is in progress and won't let me enable wireless
Hi. Problem with a Nighthawk x10 Model R90000 with the newest firmware (V1.0.5.38). I'm at a loss. It appears the WPS Wizard is running according to the router, but according to my devices it isn't...
Dec 03, 2021Guru - Experienced User
Try a factory reset and setup from scratch. Press the reset button for 10 seconds then release. Walk thru the setup wizard.
Netgear has set up a community forum specifically for the NightHawk Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
Thank you.
- glennf0908Dec 06, 2021AspirantI tried a factory reset and rebuilt the wireless setting, the WPS problem persisted. I then deleted all the backup files to ensure the factory reset wasn’t grabbing any settings, and did another factory reset, no luck, even worse. Now the router can’t find the login page even though I am hardwired. I can ping the router, and other devices that are hard wired. So I went from no Wi-Fi to no Wi-Fi and no hardwired bandwidth. I just bought a linksys router, more expensive but at least I can get tech support and don’t need a computer Science degree. Very odd this all happened after I “upgraded” the firmware, Apple battery much?
- michaelkenwardDec 07, 2021Guru - Experienced User
glennf0908 wrote:
I tried a factory reset and rebuilt the wireless setting, the WPS problem persisted.Does this mean that you are trying to use WPS and it doesn't work?
Is there still an entry for "WPS Settings" in the browser graphical user interface (GUI)?
ADVANCED > Advanced Setup > Wireless Settings.
Maybe this is one of the features removed in recent firmware on security grounds.
I just bought a linksys router, more expensive but at least I can get tech support and don’t need a computer Science degree.Does this mean that you have abandoned the R9000?
.... Apple battery much?I'll bite. What does that mean?
