StackTrace's avatar
Dec 21, 2016
Wrong subnet after firmware update
After updating the firmware, all my devices are on 10.0.0.x internal ip-numbers.  Thia used to be 192.168.0.x. My NAS is on 192.168.0.112 and is attached to 1 of the 4 lan ports on the R8000. I can...
  • StephenB's avatar
    Dec 21, 2016
    StackTrace wrote:
     How do I change the router configuration to get all my devices on 192.168.0.x so I can reach my NAS again?
    If this is a ReadyNAS you have a couple of other options.  An OS reinstall is available on the boot menu (see your device hardware manual) that resets the admin password to the factory default value, and also changes the network configuration to use DHCP/automatic addresses.  This won't affect data or other settings.
    With any reasonably new NAS (including all ReadyNAS models) you should also be able to directly connect the NAS to your PC's ethernet connection (no switches or routers in between).  The set the PC to use static IP address 192.168.0.100, subnet mask 255.255.255.0, gateway 192.168.0.1.  Then you can access the NAS by its IP address in your web browser, and reset it temporarily to use DHCP.  Obviously reset the PC to back to what it was before.
    I say "reasonably new NAS" because old devices (using fast ethernet) generally would need a special ethernet cable (called a crossover) to do this trick.  But gigabit ethernet devices should auto-sense the direct connection, and work with a normal ethernet cable.
    My overall advice is to use IP address reservation instead of assigning a static address to your NAS.  It has all the benefits of a static address and no drawbacks.  If you'd configured it that way, the NAS would still have connected to the network.
