Appleuser2000's avatar
Apr 14, 2018
Wrong Time and Date on R7000
Hello I have firmware version V1.0.9.26_10.2.31
My time and date are wrong. I set the correct time zone in Advanced-> Security->schedual. It says Monday 22 Jan 2018.The time is wrong too.
I did reset the router to factory settings (pressing the reset button the back fo 10 sec).
  • Simple question as you didn't say you did this, but did you press APPLY after setting the correct time zone and DST box?
    Also what LANGUAGE is being used?
    • Yes I did press Apply, I don't tick the DST box because in my country we don't have daylight saving, and language is English
      • IrvSp's avatar
        IrvSp
        Master
        Sorry, those were just guesses? Some languages I recall having a problem.
        Since you are probably not in the US, only a few states don't use DST, I'd think the only other possibility would be your ISP blocking the time server? R7000 uses a specific one, but I don't know what that is? I don't know for sure but I think some 3rd party firmware allows a choice for time servers, but I'd not go that route and it 'could' void any warranty you have.
        Did you have another router before that had the correct time?
        In case this is a router problem, if you just bought it, I'd exchange it to rule that out. Otherwise, contact support if in the first 90 days is all I can suggest.
