bubbalou12
Sep 10, 2022Aspirant
wyze security camera uses 2g not 5g
wyze security camera uses 2g not 5 g, my router has both . i need to split the router usage to my personal use on the 5g and a "guest" that uses the 2g as the camera says its not connecting to the 5g...
- Sep 13, 2022
common issue with lots of IOT devices honestly. I have to keep 2.4ghz quite heavily used because of that
Sep 10, 2022Guru - Experienced User
What router do you have?
Some you can disable smart connect and separate out the 2.4ghz and the 5ghz.
tough to know without knowing what you have.
Usually for setting up a device that only has 2.4ghz, you just need to make sure the device you use for setup is on 2.4ghz. so you can separate out the ssid's until the device is setup, and then combine them again
