bubbalou12's avatar
bubbalou12
wyze security camera uses 2g not 5g
wyze security camera uses 2g not 5 g, my router has both . i need to split the router usage to my personal use on the 5g and a "guest" that uses the 2g as the camera says its not connecting to the 5g...
  • kneel242's avatar
    Sep 13, 2022
    common issue with lots of IOT devices honestly.  I have to keep 2.4ghz quite heavily used because of that
