bubbalou12
Sep 10, 2022Aspirant
wyze security camera uses 2g not 5g
wyze security camera uses 2g not 5 g, my router has both . i need to split the router usage to my personal use on the 5g and a "guest" that uses the 2g as the camera says its not connecting to the 5g...
- Sep 13, 2022
common issue with lots of IOT devices honestly. I have to keep 2.4ghz quite heavily used because of that
kneel242
Sep 13, 2022Aspirant
michaelkenward
Sep 13, 2022Guru - Experienced User
Any tips on how best to go about it with your setup?
People turn up here regularly with the same problem. They might appreciate some guidance.
