NorthwestBlair
Dec 12, 2020Aspirant
X10 AD7200 r9000 Fast Ethernet but extremely slow WiFi
Hello, I am having extremely slow WiFi speeds through my Netgear x10 ad7200 router. I have a netgear cm1200 modem and gigabit internet through Cox. Anything plugged into the router through Ethernet g...
NorthwestBlair
Hi Plemans. No I am not using smart connect. It is disabled. I get the slow speeds from both 2.4ghz and 5ghz.
Dec 12, 2020Guru - Experienced User
What device/devices are you testing on?
have you tried reinstalling the firmware to the router?
Maybe something is corrupt in the firmware.I'd try reinstalling the firmware, then factory reset, and do a clean install (not from backup)
- NorthwestBlairDec 12, 2020AspirantI test it on a brand Mac book pro. We have brand new iPhone 12 max pros. We have a windows laptop. A new Sony 85” tv. It’s all the same. I try to downgrade the firmware but it’s not letting me. Every time I factory reset the router, it brings up the router login webpage and it makes me set it up as a brand new router. But it also installs the latest firmware. I can’t find a way around this. I think this is a new way that netgear is forcing the latest firmware to be installed.
- plemansDec 12, 2020Guru - Experienced User
You can disabled auto update.
https://kb.netgear.com/000038662/How-do-I-enable-disable-auto-firmware-update
and if its happening during setup, just unplug the modem from the router. Once its setup and auto-update disabled, then you can connect it back to the modem.
