Iceman64
Mar 26, 2019Guide
X10 in Bridge Mode
Can someone tell me what do I give up or gain by setting my Netgear router to 'Bridge Mode.' I have (Verizon) Fios and their Modem/Router (Quantum) for my internet, tv and phone service. Right now th...
- Mar 26, 2019
you're basically running them in double NAT. Here's a little info on it.
https://kb.netgear.com/30186/What-is-Double-NAT
Putting your X10 in bridge mode removes this problem.
https://kb.netgear.com/24105/What-is-bridge-mode-and-how-do-I-set-it-up-on-my-Nighthawk-router
antinode
Mar 27, 2019Guru
> [...] I looked at the manual, and the difference between 'AP' mode
> and 'Bridge' mode, seems confusing still.
Which "the manual"? As previously suggested, the pictures in the
R7000 User Manual might help.
A wireless access point uses a cable connection to the main router,
and serves wireless client devices in its neighborhood. An R9000 in
bridge mode uses a wireless connection to the main router, and serves
wired client devices in its neighborhood.
> [...] I just want to be able to keep as many things connected as
> 'wired' as I can, when I remove the double NAT situation.
The six LAN Ethernet ports on the R9000-as-WAP should still work.
(Or, as the R9000 User manual refers to them, "Ethernet ports 1-4".
Even a tool as valuable as copy+paste can be over-used.) And, you could
always add another (or bigger) switch, if needed.
Iceman64
Mar 27, 2019Guide
Thanks for the clarification. I talked with a Verizon Tech earlier, who walked me through setting the Fios router as a passthrough only, to my Netgear router, so it (Netgear) would have a static ip and would assign ip addresses to my devices. I'm happy with this solution. This should take care of the double NAT problem.
