Iceman64
Mar 27, 2019Guide
X10 in Bridge Mode
Can someone tell me what do I give up or gain by setting my Netgear router to 'Bridge Mode.' I have (Verizon) Fios and their Modem/Router (Quantum) for my internet, tv and phone service. Right now th...
- Mar 27, 2019
you're basically running them in double NAT. Here's a little info on it.
https://kb.netgear.com/30186/What-is-Double-NAT
Putting your X10 in bridge mode removes this problem.
https://kb.netgear.com/24105/What-is-bridge-mode-and-how-do-I-set-it-up-on-my-Nighthawk-router
ChrisJC
Apr 06, 2019Tutor
Iceman64 wrote:
Thanks for the clarification. I talked with a Verizon Tech earlier, who walked me through setting the Fios router as a passthrough only, to my Netgear router, so it (Netgear) would have a static ip and would assign ip addresses to my devices. I'm happy with this solution. This should take care of the double NAT problem.
Could you explain what the tech had you do?
Iceman64
Apr 06, 2019Guide
Sorry, I don't remember everything he had me do. I believe changing the DMZ HOST to 'enabled' for the Netgear router ipv4 address was one thing. And we disabled the 2.4 and 5 ghz wireless access points. Sorry I can't be more helpful.
