kpacumup
Mar 05, 2023Aspirant
X10 R900 5GHz wifi sticks to 802.11/a
My X10 R9000 is stuck to 802.11/a on the 5GHz wifi but my wifi connected devices support 802.11/ac. How do I make X10 R9000 to broadcast 802.11/ac? X10 is up to date with firmware. Wired speeds are ...
- Mar 08, 2023
Hello everyone,
Thank you for your time and efforts in trying to help.
However, I found the solution on another forum: Can't seem to sustain more than 54mbps wireless w/ R7000 | SmallNetBuilder Forums (snbforums.com)
It turns out 802.11 specs that hi throughput rates (anything above 54Mbps) require WMM and WPA2/AES (or no encryption).
I turned on WMM for 5GHz and voila, my SSID is 802.11ac, 80MHz channel width, up to 3467Mbps max speed.
Thank you.
Best to all and good luck
Mar 05, 2023Guru - Experienced User
What do you have your "up to ****" " speeds set to?
Have you done a wifi scan (not with windows built int) to see if its broadcasting on full width?
What device are you testing on?
