kpacumup
Mar 05, 2023Aspirant
X10 R900 5GHz wifi sticks to 802.11/a
My X10 R9000 is stuck to 802.11/a on the 5GHz wifi but my wifi connected devices support 802.11/ac. How do I make X10 R9000 to broadcast 802.11/ac? X10 is up to date with firmware. Wired speeds are ...
- Mar 08, 2023
Hello everyone,
Thank you for your time and efforts in trying to help.
However, I found the solution on another forum: Can't seem to sustain more than 54mbps wireless w/ R7000 | SmallNetBuilder Forums (snbforums.com)
It turns out 802.11 specs that hi throughput rates (anything above 54Mbps) require WMM and WPA2/AES (or no encryption).
I turned on WMM for 5GHz and voila, my SSID is 802.11ac, 80MHz channel width, up to 3467Mbps max speed.
Thank you.
Best to all and good luck
Kitsap
Mar 05, 2023Master
kpacumup wrote:My X10 R9000 is stuck to 802.11/a on the 5GHz wifi but my wifi connected devices support 802.11/ac. How do I make X10 R9000 to broadcast 802.11/ac?
X10 is up to date with firmware. Wired speeds are ok - 490Mbs download and 26Mbs upload
ISP provides 500Mb/s download /25Mb/s upload. On 5GHz my wifi connected devices get no more than 25Mb/s download and 25Mb/s upload.
Any ideas?
In Advanced -> Setup -> Wireless Setup, do you have smart connect enabled?
If yes, disable it and give each band, 2.4 GHz and 5 GHz, separate SSIDs so you can distinguish them apart when connecting from your client devices.
- kpacumupMar 06, 2023Aspirant
Here are snapshot of my R9000 settings and wifi scan by WifiInfo
- KitsapMar 06, 2023Master
kpacumup wrote:Here are snapshot of my R9000 settings and wifi scan by WifiInfo
I cannot see any image file you insert until approved by moderators. Much more efficient to attach image files. See attached. Limit to one attachment to reply. Just create more than one reply.
Attached is the Settings
