kpacumup
Mar 05, 2023Aspirant
X10 R900 5GHz wifi sticks to 802.11/a
My X10 R9000 is stuck to 802.11/a on the 5GHz wifi but my wifi connected devices support 802.11/ac. How do I make X10 R9000 to broadcast 802.11/ac? X10 is up to date with firmware. Wired speeds are ...
- Mar 08, 2023
Hello everyone,
Thank you for your time and efforts in trying to help.
However, I found the solution on another forum: Can't seem to sustain more than 54mbps wireless w/ R7000 | SmallNetBuilder Forums (snbforums.com)
It turns out 802.11 specs that hi throughput rates (anything above 54Mbps) require WMM and WPA2/AES (or no encryption).
I turned on WMM for 5GHz and voila, my SSID is 802.11ac, 80MHz channel width, up to 3467Mbps max speed.
Thank you.
Best to all and good luck
Kitsap
Mar 07, 2023Master
kpacumup wrote:Kitsap, thank you for trying to help me - I appreciate it.
Your opinion may make sense if these questions were answered:
1. The 5GHz network on the wifiinfo shows the router broadcasts 802.11/a in a 20MHz width, up to 54MBps. Why is it not broadcasting 802.11ac in a 80MHz width up to 788MBps as the other 802.11ac networks?
Please confirm, for your 5 GHz network, you have selected WPA2-PSK (AES) as the security option and have assigned a password (network key). If you are running an open Wi-Fi with no security or password it may only transmit in a 20 MHz wide channel.
2. Why is my neighbors SSID more important than mine on my router?
Your router is just a transmitter. It is up to the client device to make the connection. Different client devices have different capacities to sort out any one signal from the background noise. You appear to have a lot of background noise.
3. Why are the other SSIDs take priority over my network on my router?
See above.
4. Why are 80MHz channel widths not available to me?
In the Netgear setup screen, pick a control channel that is one of the four that make up a 80 MHz wide channel.
When connected, please confirm the connection type (802.11??) as shown in the Windows Task Manager application. Select the Performance tab then Wi-Fi. It is listed toward the bottom on the right.
kpacumup
Mar 08, 2023Aspirant
Hello everyone,
Thank you.
- FURRYe38Mar 08, 2023Guru - Experienced User
Enjoy. 📡
