81anKarlsson
Aug 24, 2018Aspirant
X10 R9000 & SilverStone DS222 = no-go?
Hi, New here since I recently got myself a Netgear X10 R9000. I have two concerns I want help with but will create a second thread for the other one. What I need help with here is that my router does ...
- Aug 26, 2018
I installed DD-WRT and the "problem" is solved.
schumaku
Aug 25, 2018Guru - Experienced User
All these embedded devices are at least one decade behind any decent desktop or server Linux distro. Kernels are historic, the UPnP code is from the early days, ... that's all. And the SoC makers deliver mostly outdated dev kit code. ODM integrating things often standardize on the "most basic" common available code. Figure. That's all.
81anKarlsson
Aug 26, 2018Aspirant
- myerswAug 26, 2018Master
Glad you found a solution. Have run DD-WRT on many routers, starting with a WRT54G in 2006. I am aways hesitent to suggest 3rd party to someone as I do not know their technical level. I do suggest Voxel's, but he is close to Netgear in look and feel with a few fixes or add ons and installs and removes just like a manual Netgear firmware install.
