dave4925
May 14, 2021Aspirant
x10 r9000 FRAG attack vulnerability
Does Netgear plan on patching firmware on the X10 R9000 relating to the FRAG attack vulnerability made public this month in which Microsoft and other vendors already patched?
michaelkenward
May 15, 2021Guru - Experienced User
dave4925
May 15, 2021Aspirant
your post is abbreviated and the link is from 2015
- michaelkenwardMay 16, 2021Guru - Experienced User
Try reading it again. Carefully.
Perhaps a different format would simplify things.
NETGEAR Product Security | NETGEAR
If you are a NETGEAR customer with a security-related support concern, you can contact NETGEAR customer support at techsupport.security@netgear.com.
- DarrenMMay 24, 2021Sr. NETGEAR Moderator
Hello Dave
You will want to check out this security advisory.
DarrenM
