AnonymousScorpi
May 15, 2020Aspirant
X10 R9000 in Bridge mode
Okay so I just upgraded my internet and TV. I am forced to use the ISP router to get my STB working. Anyhow I love my X10 and miss having my plex media center. So I want to incorporate it into my netw...
- May 16, 2020
> Okay so I tried a few things. First I tried LAN to WAN and that is not
> right. [...]Did you simply move the cable, or did you follow the instructions in
the R9000 User Manual for "Use the Router as a WiFi Access Point"?> [...] 1 is the access point [...] However I would need Ethernet ran to
> the upstairs to really benefit from this.Right.
> [...] I can do a wired bridge mode like I have. With Ethernet
> connecting the 2 routers. [...]That is not what Netgear calls "bridge mode". I don't know what you
mean by "bridge mode".> [...] Get the User Manual. Read. Look for [...]
Did you?
> [...] I than have X10 in bridge mode but not setup for wireless ( I
> skipped that part of the setup). [...]I don't know what you mean by "in bridge mode but not setup for
wireless". The whole point of (real) "bridge mode" on an R9000 is to
get a wireless connection between it and the main router (LAN). See
"Set Up the Router in Bridge Mode" in the R9000 User Manual.> [...] My main goal was to run my plex media server from the X10 and
> allow more wired devices to connect to the router [...]As explained before, that's what a wireless access point should do,
if you can use an Ethernet cable to connect the R9000-as-WAP to the main
router.
AnonymousScorpi
I chose bridge mode not because items don’t support wireless but because I prefer a wired connection whenever possible. The new router only has 4 Lan ports and instead of spending money on a network switch I figured I would just put the X10 in bridge mode and have access to more wired connections.
The wireless bridge was interesting because i could hardwire devices on the second floor and possibly receive a better connection.
Yes I understand and you are right. The manual is probably my best source for the setup process but the issues often found in certain setup modes aren’t always listed in the manuals. So real life talk to others might help in determining what typically works best.
antinode
May 15, 2020Guru
> I chose bridge mode not because items don't support wireless but
> because I prefer a wired connection whenever possible. [...]
Ok, but "bridge mode" would use a wireless connection between the
R9000 and your main router. Moreover, I believe that the R9000 wireless
(in that mode) would be dedicated exclusively to that connection to the
main router.
> [...] The new router only has 4 Lan ports and instead of spending
That's what wireless-access-point mode would do. And, it would give
you a wireless access point (whose radios could be disabled, if you
wanted).
A wireless access point is called that because it provides wireless
access to client devices, not because it uses a wireless connection to
the LAN. (It uses a wired connection to the main router.)
You'd get a better (wired) connection between client devices and the
R9000-as-bridge, but you'd then have a wireless connection between the
R9000-as-bridge and your main router. That could be useful if you can't
run an Ethernet cable (or equivalent) between the main router and the
R9000 ("on the second floor"?).
