ladyl
Feb 20, 2022Aspirant
X10 R9000 Issues with Ubee UBC1322
I had a new modem from optimum (UBC1322) cable modem+router. Didn't realize they had the router enabled on my modem, so it was messing up Netgear R9000 setup. I had the ISP set it to bridge mode - an...
Feb 20, 2022Guru - Experienced User
Does the Internet LED on the router turn AMBER at all?
Check with your ISP to ensure the modem is fully bridge and if any user account configurations is needed, like PPPoE, this should be reviewed and checked as well.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Set the ISP Modem back to router mode and try the following:
1. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
23. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
- ladylFeb 20, 2022Aspirant
The Internet LED blinks white.
I did the power off/on on all the devices in that order as well, but same result.
Also something weird with Safari (chrome is fine) -- I typed in amazon.com/videohelp and it prompts me to enter my Netgear S/N and then asks for my security questions to reset my router password. I don't remeber either so the page gets stuck. I open a new window (in private mode) and put in a fully qualified url https://amazon.com/videohelp and page resolves fine.
I'm unable to do change the cable modem mode myself - I had to call the ISP to setup bridge mode remotely. They confirmed via phone it was set to bridge mode, but It's weird how I can still connect to the SSID setup with cable/router. I have a service appointment maybe they need to do something else with PPOE as you suggested. I'll have them go through the Nighthawk setup with me again.
