ladyl
Feb 20, 2022Aspirant
X10 R9000 Issues with Ubee UBC1322
I had a new modem from optimum (UBC1322) cable modem+router. Didn't realize they had the router enabled on my modem, so it was messing up Netgear R9000 setup. I had the ISP set it to bridge mode - an...
ladyl
The Internet LED blinks white.
I did the power off/on on all the devices in that order as well, but same result.
Also something weird with Safari (chrome is fine) -- I typed in amazon.com/videohelp and it prompts me to enter my Netgear S/N and then asks for my security questions to reset my router password. I don't remeber either so the page gets stuck. I open a new window (in private mode) and put in a fully qualified url https://amazon.com/videohelp and page resolves fine.
I'm unable to do change the cable modem mode myself - I had to call the ISP to setup bridge mode remotely. They confirmed via phone it was set to bridge mode, but It's weird how I can still connect to the SSID setup with cable/router. I have a service appointment maybe they need to do something else with PPOE as you suggested. I'll have them go through the Nighthawk setup with me again.
Feb 20, 2022Guru - Experienced User
Ya, have them confirm on site the configuration of the modem. IF your still seeing the SSID broadcast from the modem, its not in bridge mode.
- ladylFeb 21, 2022AspirantSeems this modem — cannot be in bridge mode. I may just need to get my own modem.
- FURRYe38Feb 21, 2022Guru - Experienced User
Try option #1 from my suggestions...
- ladylFeb 21, 2022AspirantOk thanks I will take a closer look at #1.
Other than Prime Video, everything else streams and gets internet fine with Netgear Nighthawk (Netflix, hbo, etc). It’s very puzzling - with the netgear app, it says offline, but when I trigger the speed test, I’m getting download/upload traffic.
