itskamel
Jul 09, 2017Tutor
X10 R9000 Wireless Roaming
I recently changed to a X10 and had previous wireless roaming setup. The 2.4 band is fine. However with Netgear wifi analystics app I can See 2 different 5ghz bands. They are named Identical. Anyone ...
- Aug 13, 2017
Hi itskamel,
The R9000 does not support wireless roaming. It will be listed as a different network even if you name it same as other networks.
JamesGL
Jul 16, 2017NETGEAR Employee Retired
Hi itskamel,
On your device network settings, can you detect two 5Ghz?
- itskamelJul 17, 2017Tutor
yes, I can. Whats the fix for that?
- JamesGLJul 19, 2017NETGEAR Employee Retired
Hi itskamel,
Your computer should support AD connection for you to able to connect to the 2nd 5Ghz.
- itskamelJul 20, 2017Tutor
So its created automatically? but named the same? no where to change the name of the 2nd 5ghz network?
I am currently showing 2 5ghz networks. the 60hz network is named with a -60hz on the end of it. are you refering to the 60hz network?
