itskamel
Jul 09, 2017Tutor
X10 R9000 Wireless Roaming
I recently changed to a X10 and had previous wireless roaming setup. The 2.4 band is fine. However with Netgear wifi analystics app I can See 2 different 5ghz bands. They are named Identical. Anyone ...
- Aug 13, 2017
Hi itskamel,
The R9000 does not support wireless roaming. It will be listed as a different network even if you name it same as other networks.
itskamel
Aug 06, 2017Tutor
after checking it is not one of the access points. it is the r9000 that is seperating itself. when i use wifianalystics it shows my other 2 access points under the same name and channel numbers. the r9000 is not listed under it but another by itself.. any help would be appreciated.
